Home › Forum › Ask A Member › the phantom primer solenoid › Re: the phantom primer solenoid
May 5, 2018 at 11:40 am
#75381
There is a grounding wire from block to ground, and Ive tried three different solenoids. Seems to be a bad ground; if the solenoid isnt on the bracket it works.
Im going to ground it to the block directly and be done with it and will report back. Oddball situation that I dont have time to waste on this time of the year!!!!
