Home Forum Ask A Member 1955 RDE-17 25 HP Johnson-mercury switch wire Re: 1955 RDE-17 25 HP Johnson-mercury switch wire
#80302
outboardnut
    You were right Buc
    The hole was hidden by the hood seal.I ‘m surprised that Johnson never put a grommet there to prevent chaffing.
    Now I need to figure out what to use to cut a 2 inch hole in the front lower pan for the carb to breathe
