F/S,40s/50s Omc special tools,in CT
All your for sale items here
Forum rules
Review Classified Ad requirements before posting in the Read First section.
gizmoh
Postby gizmoh » Mon Jan 29, 2018 11:19 am
I've been doing a bit of cleaning around the shop.I found 2 duplicate (to me) special tools.First is 376048 gauge.This properly sets the coil air gap on the 40s "rotor"coils.This style coil laminates face inward towards a magnetic rotor on the crankshaft.This tool replaces the rotor and the coils can be pushed against the tool (lightly),and tightened.Remove the gague and replace the rotor.Done.$15.00.Next is the pressure testing tool for the 2 line tanks.It plugs into the motor end and your tank fitting plugs into the opposite end of the tool.This allows you to check the operating fuel pressure.Also has a shut off that allows you to see if the check valve at the bottom of the reed plate is leaking.Can also detect leaks within the tank itself.You will nee a length of 3/16 i.d. hose and a 15 lb.pressure gauge.Any plumbing store will have them.$50.00. Actual shipping cost only.Call Ken at 860 941-7755 or ken1401732@aol.com
Return to “Free Classifieds”
