FS: Bendix Eclipse ELECTRIC Outboard (NNY)
All your for sale items here
Forum rules
Review Classified Ad requirements before posting in the Read First section.
Chinewalker
Postby Chinewalker » Fri Feb 09, 2018 3:07 pm
This is a nice, original Eclipse Electric Outboard Motor from the Bendix Corporation, c. 1937. These early electrics are uncommon, if not rare. Ads proclaimed it as only weighing 20 lbs.!
This motor has been tested and it does run! The selector switch worked fine for OFF, SLOW and FAST positions. The down tube shows some light rust spots where the plating has flaked off, and there is a fair bit of wear to the paint. The wiring harness is intact, but shows some weather checking/cracks to the outer sheathing, electric tape at the motor-end, etc. We only bench tested the motor and did not run it in the water. It is recommended that the buyer inspect any seals in the submerged motor assembly prior to immersing in water.
Asking $400.00. Willing to ship on your dime. Probably be about 35 lbs. by the time it's packed up, from 13624.
E-mail: csr112-n AT twcny DOT rr DOT com
Return to “Free Classifieds”
Users browsing this forum: Dave Bernard and 2 guests
