Home Forum Ask A Member 1954 Gale mfg Hiawatha 3 hp Re: 1954 Gale mfg Hiawatha 3 hp
#83476
elfritzer
    Very interesting, but my lower unit does not come apart at a torpedo shaped joint. Also, if I take the upper apart soon , and I find a place to put a copper tube, where does it plug into the bottom? My water pump is just a teeny thing. It appears to have some clearance on the excentric, how big is the gap supposed to be? If it needs to be bigger, can I just drill out the rubber part?
