Re: Thin Gasket Material?
Home Forum Ask A Member Thin Gasket Material? Re: Thin Gasket Material?
Topics: 298
#69756
If you go with gaskets made from old magazines, try and use the high quality shiny paper which is usually used on the covers. It’s sulphite paper, similar to the stuff used for photographs and it’s much denser than dull paper or brown paper bags, which are usually made from kraft pulp. Using a micrometer will help you find the desired thickness.
