Home › Forum › Ask A Member › Prop question: how can you tell pitch? Or if the hub is spun? › Re: Prop question: how can you tell pitch? Or if the hub is spun?
April 24, 2018 at 3:35 am
#74627
Measure the prop on a pitch gauge. Some times there will be damage on the back side of the hub, a whole lot of grooving or scoring as the drive pin spins by the hub.
