Home › Forum › Ask A Member › Need suggestions on SMALL 12 volt starter solenoid for 1955 RDE-17 25 Hp Johnson › Re: Need suggestions on SMALL 12 volt starter solenoid for 1955 RDE-17 25 Hp Johnson
August 2, 2018 at 6:50 pm
#80555
A direct 12 volt replacement is Sierra 18-5807, but it will be the same size as the 6 volt one you are replacing. It was used in 35 and 40 HP Johnsons beginning in 1957 when they changed to 12 volts.
