Re: Help with 65′ Evinrude Fisherman 6HP
Home › Forum › Ask A Member › Help with 65′ Evinrude Fisherman 6HP › Re: Help with 65′ Evinrude Fisherman 6HP
see picture
btw here is where I had picked up the habit of using TOP to set my points before using the VOM or with Richard’s (FR) tool
it came from the MAX rule site…
To set the points, move the cam until the point arm follower is touching the cam at the "TOP" embossed thereon. Set them at .020 with a feeler gauge cleaned of all oil with denatured alcohol, acetone or lacquer thinner. The feeler gauge should slip out from between the point faces with a light resistance and the arm should not appear to move when the gauge is removed. Care taken to set the points exactly the same will result in a strong spark and a smooth running engine.
