Merc-o-tronic 9800
Home Forum Ask A Member Merc-o-tronic 9800
  • gofastgramps
    Topics: 25
    #4860
    I have a merc-o-tronic model 9800 that runs on the internal battery or 12 Volt external battery. I need any information that I can get on it. does the functions that normally use 120 volt work on battery power? If so which battery. any info would be appreciated. Gary
    mercuryman
    Topics: 167
    #41078
    Not sure what you need, I use a 7.5 volt rechargeable model car battery. It cost about $15 with charger. The 120 volt AC is used in testing capacitors and 7.5 volt DC for coil test.
    mercuryman
    Topics: 167
    #41086
    You can find a manual on internet you can copy.
    gofastgramps
    Topics: 25
    #41164
    this tester does not have a 120 volt plug. Gary
    mercuryman
    Topics: 167
    #41168
    I gave you wrong info I have the Model 98 which must be different than 9800. It must make AC voltage from the battery as it has a circuit board.
