Home Forum Ask A Member 1956 Johnson 30HP internal wiring harness advice needed.. Re: 1956 Johnson 30HP internal wiring harness advice needed..
#54739
huntleybill
    Thank you Garry, Frank…that worked. The solenoid was in upside down.
    Looks like I should replace it anyway. The posts for the battery cables are stripped. Are these solenoids available? Where can I get one?
    Thank you again for all your help
