Home Forum Ask A Member Evinrude 4423 3.3hp Fuel tank Re: Evinrude 4423 3.3hp Fuel tank
#70412
    The 51813 Gasket Maker was used on this 4425 tank with good results. You can see the three coil screws (with the heads cut off) used for the alignment of the two halves. It’s been close to four years now and no leaks yet!
