Home Forum Ask A Member HELP-Evin. mod 6302s 6hp impeller problem Re: HELP-Evin. mod 6302s 6hp impeller problem
#70440
Doug Wilson
    Might try using wooden door shims and keep adding them to put pressure on it while turning the crank shaft back and forth should pop off
    Doug
    turned off?
