Home Forum Ask A Member Aluminum Polishing Issues Re: Aluminum Polishing Issues
#72733
20mercman
    quote putback:
    I’ve done a lot of alum buffing on vintage Airstreams and old alum boats. Never found a shortcut. I generally use a dewalt angle polisher with an Airway cotton cloth edge wheel and bar buffing compound. Busch Enterprises has the materials and good info. I rarely use sandpaper eventually you have to buff deeper than the deepest scratch where as the Tripoli Bar [brown] #63030 compound is a fast aggressive 1st cut, then you can skip to white bar #63020 to polish. On decient grade aluminum you will get a mirror finish. Now if, BIG IF, its possible the black stains were caused by back and forth sanding, resetting the removed material back into the just polished alum.Yea, sounds foolish, read the info at the Busch site. Try wiping it with accitone or even alcohal. Polish one direction if possible. The wheel compound technique will do well on and around the letters but beware of “molecular migration”, [with experiance you can use that problem to fill pits!] agian Busch site. What I think I see in the pic I’d guess less than 2 hrs to finish.
    I have a 1975 31′ Airstream……………….if you have some spare time… 😆
