Re: Running a 50’s OMC in a barrel
Home › Forum › Ask A Member › Running a 50’s OMC in a barrel › Re: Running a 50’s OMC in a barrel
March 23, 2018 at 11:50 pm
#72931
I’m sure I have run many fewer engines in a tank (55 gallon plastic barrel in my case) than many on this forum, but I have run a bunch of them. I have never had to remove that cover. I did have a motor with a solid cover over the bypass. I never tried running that solid cover plate in the tank. I never had a problem with overheating with the ones I have run assuming the pump is working properly.
-Ben
OldJohnnyRude on YouTube
