Home Forum Ask A Member Prop question: how can you tell pitch? Or if the hub is spun? Re: Prop question: how can you tell pitch? Or if the hub is spun?
#74633
chinewalker
    Sometimes, if I have a propshaft for a similar motor in the pile, I’ll set it up in a vice and mount the prop. If it’s spun, I can turn it by hand with much effort. Often, a badly spun prop will be apparent with a visual inspection.
