Re: 1957 Evinrude 18HP ignition issues
Home › Forum › Ask A Member › 1957 Evinrude 18HP ignition issues › Re: 1957 Evinrude 18HP ignition issues
May 3, 2018 at 5:29 pm
#75283
Wow! Thank you for all the good info!!
Aftr Crosbys response, I decided to replace the old points I took off and use the Timing tool again and TA DA! It now lines up! The points I bought off of ebay were either wrong ones or just crap. The rubbing foot was definitely bigger.
I would not have thought of this! I was starting to think I was losing my mind in some fashion(which I probably am BTW)
Thank you again.
I will now go out to run it and update…..
