Home › Forum › Ask A Member › 10hp Johnson. › Re: 10hp Johnson.
Yes, if you do the fuel pump conversion it will run on a standard single line tank. There is no conversion "kit" per se, but you can look on utube or do a google search for "OMC fuel pump conversion" and you can find out how to do it. There are 2 different options on how to modify the motor intake to make it work – you can find both options on utube. Or maybe another member has a video or written instructions on how it’s done.
