Home Forum Ask A Member 1930 Elto Speedster Model 310, 14 hp Re: 1930 Elto Speedster Model 310, 14 hp
#76318
squierka39
    The timer is just on ny friction, with a screw for tension. Like the mag plates are. I’ll try to get some better lighting and take a few more pics, might take a few days though. The flywheel had the cam cast in and a small connecting rod activates the points inside the timer box. Works the same as a ruddertiwn if you’ve ever seen one in action.
