1965 9.5 Johnson, drain plug gasket source?
Jmay
Postby Jmay » Sat Nov 11, 2017 8:32 pm
In the parts list I've seen on-line (have not been able to locate a parts manual for my 1965 Johnson 9.5 hp outboard), I see drain plugs listed (with or without gaskets) but do not see the gaskets listed. I've checked with my local hardware store and they did not have one. Do any of you have a source for these? I can buy the plug - it just seems like a waste when I don't need it.
Thanks,
Jim May
david bartlett
Re: 1965 9.5 Johnson, drain plug gasket source?
Postby david bartlett » Sat Nov 11, 2017 8:47 pm
Jim,
Welcome! I found a part # 311598. Sierra # 18-4248-9(5 pack) 18-42481-9(50 pack)
These numbers are from my Fastwin parts book, but should work OK.
Last edited by david bartlett on Sat Nov 11, 2017 8:52 pm, edited 1 time in total.
Member Pine Tree Boating Club chapter of AOMCI
"I don't fully understand everything I know."
"There is nothing — absolutely nothing — half so much worth doing as simply messing about in boats." (Kenneth Grahame)
Jmay
Postby Jmay » Sat Nov 11, 2017 8:50 pm
Thank you David - much appreciated.
Jim
outbdnut2
Postby outbdnut2 » Sun Nov 12, 2017 11:49 am
Those fit just about every Johnson/Evinrude/Mercury and a bunch of others from the 1950s up through today.
Users browsing this forum: No registered users and 14 guests
