Home Forum Ask A Member Pressure Tank Leaking Re: Pressure Tank Leaking
#76549
aquasonic
    What I don’t see in the picture is any evidence of sealant being used. Also, not sure if the washers are present under the flanged screws for the top casting. As Chris said, the diaphragm penetration needs to be sealed, but also the top gasket and top screws need sealant.
