Home Forum Ask A Member Swivel bracket lubrication fitting Re: Swivel bracket lubrication fitting
#77449
rpsiii
    Jim,
    Unscrew the connector (nozzle) piece from the end of the gun a bit and it should make
    connecting and disconnecting from the fittings much easier. Nothing should "leak" and you
    won’t need to remove the gun with any force. Has always worked for me with all the
    grease guns I’ve handled!!
    Respectfully
