Home Forum Ask A Member OEM support for trailering Re: OEM support for trailering
#77553
outbdnut2
    Here’s the factory lock that screws in from the side of the transom clamp on my 1958 RD 35 HP Johnson. The handle on the right is the regular transom clamp, the handle on the left screws in from the side with the motor tilted up to hold it up. This is probably one of the types Frank said broke on rough roads:
