Home Forum Ask A Member OMC Dual Line Fuel Tank Pick-up tube Re: OMC Dual Line Fuel Tank Pick-up tube
#77618
    quote Garry in Tampa:
    A single line tank doesn’t have any valves. The valves are in the primer bulb in it’s fuel line. . .
    That would make sense Garry!
    I didn’t think about it until I had my dual line guts all back together,
    but does the primer button pressurize the tank to move fuel,
    or suck it up the pickup tube?
    I got the homemade check valve disc to work good now. I must be smarter in
    the morning. 😕 I realized the pickup tube protrudes into the check valve
    body slightly, and the tube has a notched end, that keeps the disc from
    opening too far, yet allows fuel to get into the tube.
    I thought I had the original pickup screen pretty clean with wire brushing and
    solvent, but decided to take the old screen out, and I was aghast at the amount
    of crud in, and behind the screen. Decided to make a new screen!
    Also, tore apart a rusty / crusty tank assembly from an OMC single line tank
    to measure the O-rings. The two little valves behind the core plugs have
    a tapered seat, and the o-rings I removed had a tapered ID.
    Whether the taper in the o-ring was manufactured or just took that shape
    from years of spring pressure on the tapered valve, I don’t know.
    Anyone know for sure?
    The closest I could measure these o-rings are…..
    OD- .325
    ID- .170
    CS- .075 (cross section / wall thickness)
    The closest I see in an O-ring size chart is OD- 5/16" x ID 3/16" x CS 1/16".
