Home Forum Ask A Member Need help identifying mercury 22 cu in block Re: Need help identifying mercury 22 cu in block
#77657
bobvdinghyracer
    1 way to tell what it is ..black paint, offset plugs = 22ci padded block … , the best of all … going backwards no offset plugs / black block = not padded .. is basicly same as a mk28 or a 250 , those were all white blocks as far as i kno , imo… the 250 was no big deal … little hotter porting but thats it and if ya want the same as that with the others then open up the ex ports … not a big deal ..no real secrets to it (leave the intakes alone )
