Home › Forum › Ask A Member › 1967 E-rude 6hp 6702S › Re: 1967 E-rude 6hp 6702S
June 8, 2018 at 10:10 pm
#77676
Very similar to the 5.5, but thankfully you don’t need to pull the powerhead to do the impeller. Just remove the four bolts, and you can drop the lower down far enough to disconnect the shift coupler.
