Home › Forum › Ask A Member › 1963 Evinrude 10 HP running problem › Re: 1963 Evinrude 10 HP running problem
June 29, 2018 at 6:40 pm
#78680
I agree.Cylinder cutting out.Sometimes the coil can be good but the ignition wire connecting to that small pin in the tunnel of the coil is corroded or pin is starting to crack.Same thing with the connection to the pin insert to the spark plugs.
