Home Forum Ask A Member 1963 Evinrude 10 HP running problem Re: 1963 Evinrude 10 HP running problem
#78748
    Is there a matching hole burned through the coil, or is that burn mark on the plate from an old cracked coil? Well anyhow, I also see a burn mark on the coil’s spark tower. Might be arcing through to the plate.
