Re: Help With An Impeller
Home › Forum › Ask A Member › Help With An Impeller › Re: Help With An Impeller
I had this in my notes, so if the 52 and 53 are the same,
you’re in luck…….
Re: 1952 evinrude fleetwin water pump info
Postby Chinewalker ยป Wed May 17, 2017 3:42 pm
I have used the OMC/BRP 277181 impeller with good success. You must "thin it", though, to make it work. The side profile of the Fleetwin impeller is smaller, so I took the new impeller and thinned it on a belt sander. Flip frequently to take equal amounts off both sides until the profile dimension is the same as the one you removed. Take care to keep the impeller flat on the sander as you don’t want it uneven, either… My ’53 pumped great with its new impeller after this modification!
