Home › Forum › Ask A Member › 1949 Johnson 10hp QD-10 igntion questions › Re: 1949 Johnson 10hp QD-10 igntion questions
2nd Update
I’ve swapped the laminations from the old 580040 coils onto the new ones I purchased (18-5181). Here are the best directions I found on how to to the modifications to the coils and the mag plate underneath. http://www.mlaoc.ca/uploads/1/0/5/9/10597650/johnson_qd_coils.pdf
I’ll post more pictures when I pick up some replacement ignition wires. Right now I’m using the old ones and they can be routed better. But the best part is I now have spark on both cylinders! Going to have to pull the mag plate off again to secure the new wires so I haven’t tried running the motor yet.
View of mag plate with old coils:
Difference in coil laminations:
Comparison between new and old on mag plate
Mag plate with new coils
