Re: 1952 Johnson Seahorse RD12 25 HP – Removing Flywheel and Source for Ignition Parts
Home › Forum › Ask A Member › 1952 Johnson Seahorse RD12 25 HP – Removing Flywheel and Source for Ignition Parts › Re: 1952 Johnson Seahorse RD12 25 HP – Removing Flywheel and Source for Ignition Parts
August 16, 2018 at 4:27 pm
#81306
Nicely spotted! Both coil wires are indeed worn, one through the insulation to the wire, and the 2nd almost as bad. That explains why one cylinder has no spark and the other intermittent (at best), as they have clearly been grounding out due to rubbing.
I will go ahead and replace everything, ordering the parts through http://www.marineengine.com/
MANY thanks for everyone’s contributions. I’ll post if I encounter any problems.
Cheers,
John
