Re: 1954 Gale mfg Hiawatha 3 hp
Home › Forum › Ask A Member › 1954 Gale mfg Hiawatha 3 hp › Re: 1954 Gale mfg Hiawatha 3 hp
August 24, 2018 at 9:13 pm
#81719
Not the motor I have. This one says viking, mine says Hiawatha and has the rewind mounted on top. I’d put a pic, but having trouble with that at this time. The diagram you sent is pretty much the same as the one I have. Where the water is leaking out is a cast alum cap that mounts to pn 22 in diagram right where the spark plug is. It has two little arms that come out, similar to the single arm on diagram pn 22. Looks like they would hold a bolt that held something that swiveled on that pivot point.
