Home › Forum › Ask A Member › Sound deading material. › Re: Sound deading material.
September 11, 2018 at 3:14 am
#82610
There are rolls of thin (approx 1/4 inch) foam insulation with foil on one side and stickyback adhesive on the other available at a lot of hardware stores. Old car restorers put it under carpeting and behind the rear seat back to reduce road noise – this stuff may stick inside outboard cowls, but I’ve never tried that. The stuff is a lot cheaper than what looks like the same stuff marketed for the car hobby. Old car resto TV show "Garage Squad" often uses this, and tells you to get it at a hardware store.
