Home › Forum › Ask A Member › 1983 OMC tach operation › Re: 1983 OMC tach operation
September 13, 2018 at 2:34 pm
#82795
quote BillW:
Believe it or not, I have had some luck, in multiple boats, taking a screw driver and turning the pole adjustment switch back and forth a few times, then putting it back on the correct setting. It’s like the switch contacts were dirty. Your results may vary; but it’s worked for me quite a few times….
Sure seems like an easy solution, will only take a few minutes….Worth a try…
