Re: lauson outboard motor
Home › Forum › Ask A Member › lauson outboard motor › Re: lauson outboard motor
September 14, 2018 at 5:57 am
#82850
No water pump on the Lauson motors. Air cooled like on the lawn mowers. Unless it is a 410 model, the sump takes about 20 ounces 30 wt non detergent oil. The points are gapped 0.020". Spark plugs 0.025". You will find the model number under the front cowling between the transom clamps. The cowlings are important on these motors as they help keep the engine cooler.
