Home Forum Ask A Member Adhesive for 1963 Evinrude Fastwin Cowl Gasket Re: Adhesive for 1963 Evinrude Fastwin Cowl Gasket
#82978
amuller
    I suspect the yellow stuff will work if you do as stated above. It is hard to use neatly because it has to tack up. There is some stuff sold by Mercury for securing boots on stern drives that might be stronger.
