Home › Forum › Ask A Member › 1954 Gale mfg Hiawatha 3 hp › Re: 1954 Gale mfg Hiawatha 3 hp
September 24, 2018 at 9:16 pm
#83476
Very interesting, but my lower unit does not come apart at a torpedo shaped joint. Also, if I take the upper apart soon , and I find a place to put a copper tube, where does it plug into the bottom? My water pump is just a teeny thing. It appears to have some clearance on the excentric, how big is the gap supposed to be? If it needs to be bigger, can I just drill out the rubber part?
