Home › Forum › Ask A Member › Advice for cutting a flywheel off › Re: Advice for cutting a flywheel off
October 28, 2018 at 1:56 pm
#85098
David Bartlett is exactly right. Tighten the puller down as tight as it will go without breaking something and then whack the center puller bolt with a 2lb STEEL hammer. That SOB will pop right off. The lead hammer does not produce the needed SHARP blow.
Steve Stevens
