Re: Johnson JW-19 Prop shaft seal standard drive Home › Forum › Ask A Member › Johnson JW-19 Prop shaft seal standard drive › Re: Johnson JW-19 Prop shaft seal standard drive crosbymanCanada Member - 2 YearsReplies: 3589Topics: 326 October 29, 2018 at 2:19 pm #85162 try one from another year’s listing … probably all the same size seal shops also have something that fits if you know the measurements Joining AOMCI has priviledges 🙂
