Re: Evinrude zephyr 4404 pull start question
Home Forum Ask A Member Evinrude zephyr 4404 pull start question Re: Evinrude zephyr 4404 pull start question
Topics: 31
#85171
You should also have threaded holes in the top of the gas tank.
This shows a little better how it goes together. . .
Because of slight differences in castings, the hub of the starter pulley should be centered on the crankshaft after the housing is firmly in place. The 395460 is the most popular rewind spring used in both Evinrude’s and Johnsons. It is also available as Sierra Marine part number 18-6501. Most AOMCI members make there own 43A195 pawl springs. 😀
