help taking apart 10hp chris craft lower
jjkdrees
Postby jjkdrees » Fri Jul 14, 2017 1:18 pm
in the lower unit I've got the prop off and i'm down to the impellar housing, I dont know how to get the housing out. Does anyone know the trick im missing
thanks
Josh
Re: help taking apart 10hp chris craft lower
Postby Dave Bernard » Fri Jul 14, 2017 3:13 pm
If the impeller is behind the prop then put the prop shaft in a vice and tap on the housing carefully. it should bring the shaft and guts out as an assembly. watch for shims. make sure the drain plug is out so it wont create a suction.
Postby Jerry Ahrens » Sat Jul 15, 2017 6:58 am
Before you do that, be sure to remove the retaining ring AND the impeller housing lock pin... The lock pin keeps the impeller housing from rotating while the motor is in operation. if you try to force the housing out without removing this little pin first (#269 in the diagram below), you end up breaking out the impeller housing.
Be careful, as Commander parts are hard to come by. http://www.chriscraftoutboards.com/commander_lower.html
jjkdrees
Postby jjkdrees » Mon Jul 17, 2017 3:12 pm
thanks for the input, I did get it apart, just alot of crud in there. again thanks for the help
Users browsing this forum: Bob D, Buccaneer and 4 guests
