New OMC mag. coils $27.00 a pair
bookfuzz
Postby bookfuzz » Tue Apr 17, 2018 2:51 pm
Just got a couple pairs of new OMC Magneto coils from Ebay. From: joystartshere
Wonder if anyone has used these. So cheep I had to order some.
Milwaukee Member Phil
twostroke
Re: New OMC mag. coils $27.00 a pair
Postby twostroke » Tue Apr 17, 2018 3:36 pm
I've used a bunch of 'em. They seem to work fine, and they're certainly cheap enough. I bought the last batch for $10/ea in a lot of 12.
Jim
I say "Pardon Me" a lot. I had a 20H with a toilet bowl, then raced open mod sleds. :D
crosbyman
Postby crosbyman » Tue Apr 17, 2018 5:00 pm
I installed a pair in a 9.5
they tested (electrically) OK.... good screw pin for the high voltage connection and they fired up good (good strong spark)
can't beat the price so I ordered up 2 pairs for my next projects. OMC square fuel pumps are cheap also so I fitted one on my 6R74 and will be doing some lake testing when this stupid temperature breaks .
kirkp
Postby kirkp » Tue Apr 17, 2018 6:53 pm
How are the windings attached to the laminate? Do they use the metal tab bent over to hold it or are they glued?
Kirk
crosbyman
Postby crosbyman » Tue Apr 17, 2018 10:48 pm
well... they look glued
coil
coil tab.jpg (121.72 KiB) Viewed 152 times
kirkp
Postby kirkp » Tue Apr 17, 2018 11:00 pm
Wonder if it's possible to remove them when they are glued? Need some windings for a different set of laminates.
twostroke
Postby twostroke » Wed Apr 18, 2018 4:24 am
They're glued.....if you support the coil in a vise, they knock right out. I've got a set on modified original laminates in my soon-to-be-restored OA-55.
Jim
The coil conversion was done with Tubs' guidance and instruction. It'll fire at .100+ gap at hand cranking speed.
kirkp
Postby kirkp » Wed Apr 18, 2018 11:39 am
Thanks twostroke
Users browsing this forum: checkmate57, Google [Bot] and 8 guests
