condensers for a mq or 9622a 9.5 hp
crosbyman
Postby crosbyman » Thu Jun 14, 2018 2:57 pm
what should the value be ??
thanks
Richard A. White
Re: condensers for a mq or 9622a 9.5 hp
Postby Richard A. White » Thu Jun 14, 2018 3:28 pm
.22 mfd should do the trick, as that is the Universal Mag
Richard A. White
MOB Chapter President
Postby Mumbles » Thu Jun 14, 2018 5:36 pm
P/N 580321 at your friendly BRP dealer.
Monetary value? A lot less than what they charge for them! I'm down to buffing my old ones and reusing them! :shock:
9.5 Mag Plate.JPG (2.93 MiB) Viewed 87 times
crosbyman
Postby crosbyman » Thu Jun 14, 2018 5:56 pm
any consequences on something around .300
mumbles... nice buffing job :-)
Richard A. White
Postby Richard A. White » Thu Jun 14, 2018 6:47 pm
They are a common condenser, not sure why you would want to use something else.....
Richard A. White
crosbyman
Postby crosbyman » Thu Jun 14, 2018 7:27 pm
they were in the motor and of equal capacitance as measured.... I'll install some .22 but...
what does extra capacitance do to performance ?? increase protection on points or.... drop s the quick on the coil primaries
Postby FrankR » Thu Jun 14, 2018 9:40 pm
Think of the condenser as a closed water pressure tank. Suppose the tank holds 2 gallons and you force one gallon of water into it. Pressure inside will rise to a certain amount. Now, lets say the tank size holds 3 gallons and you force the same one gallon of water into it. Pressure inside will rise to a lesser amount than before.
Now as applied to condensers, if you force a certain amount of electricity into it, pressure inside will rise to a certain amount. In this example, "pressure" is called "Volts". A larger condenser capacity will result in lower Voltage buildup, assuming the same amount of electricity.
It matters because it determines the voltage of the electricity as it discharges back out through the coil when the points break. That reversal back through the coil is part of what creates a spark at the plug.
Users browsing this forum: NJ-boatbuilder57 and 9 guests
