TRIM outboard
bill_loveland
TRIM outboard
Postby bill_loveland » Thu Jun 14, 2018 11:22 pm
At the Mecum/Jim Street auction, there was a beautiful TRIM outboard. I just ran across a very similar looking motor from Lutetia while prowling Jack's site. Does anybody know about the TRIM? I believe it is Swedish, although the example at the auction had English instructions. Were the companies associated? Would a Swedish company build a French company's design in 1932 (or vice versa)?
trim outboard Capture.PNG (842.45 KiB) Viewed 960 times
http://www.cailleoutboards.com/rowboat/ ... tetia.html
Dan in TN
Re: TRIM outboard
Postby Dan in TN » Fri Jun 15, 2018 12:00 am
I sent you a PM.
Dan in TN
melugin
Re: TRIM outboard
Postby melugin » Fri Jun 15, 2018 11:11 am
I have Streets' Trim. It is 22hp, service model. The lubrication instructions are in English on one side of the tank and Swedish on the other. Any tune-up info would be appreciated. I see quite a similarity to the Lutetia.
kees
Re: TRIM outboard
Postby kees » Fri Jun 15, 2018 12:21 pm
melugin wrote:I have Streets' Trim. It is 22hp, service model. The lubrication instructions are in English on one side of the tank and Swedish on the other. Any tune-up info would be appreciated. I see quite a similarity to the Lutetia.
the model C or CP develops 20 - 22 hp, so that's your model
and its a little rare and hard to find
the real race motor was the model "CR"
more common are the 2-cyl. models "T" and the model "A" ( 4 - 6 hp )
I don't have tune-up info, but maybe one of our members from Sweden jumps in .
kees
Re: TRIM outboard
Postby kees » Fri Jun 15, 2018 12:33 pm
bill_loveland wrote:At the Mecum/Jim Street auction, there was a beautiful TRIM outboard. I just ran across a very similar looking motor from Lutetia while prowling Jack's site. Does anybody know about the TRIM? I believe it is Swedish, although the example at the auction had English instructions. Were the companies associated? Would a Swedish company build a French company's design in 1932 (or vice versa)?
[size=150]IMHO there was no technical cooperation between the French and Swedish, but...........
you can always accuse every company , also in those days, for stealing and copying designs from each other
AND OF COURSE , THEY DID !
and , say by yourself, every outboard looks basically the same
http://www.cailleoutboards.com/rowboat/ ... tetia.html[/size]
Users browsing this forum: crosbyman, mercuryman, outbdnut2 and 9 guests
