Home Forum Ask A Member 1976 merc 110
  • #16068
    billy-t
      billy-t
        [imghttp://www.marineengine.com/parts/mercury_marine_parts/static/img/COMMON/38649.gif][/img]
        #16075
        jasonh
          Put in reverse, remove nut (facing down, #3 on image 2 under cavitation plate where intake screen (#8 image 1) is mounted and remove nut (facing up on top of stud #2 on image 1) under dynafloat cradle at front (front of boat) of exhaust housing. should drop down. shift shaft is splined like driveshaft.
          #16107
          chinewalker
            Two nuts. On on underside of AV plate, other on leading edge below the swivel bracket.
            #16110
            ddoyle
              Before taking it apart pick up both size impellers at NAPA install the one that fits and exchange the other one for a spare. Lining stuff up is not all that tough, have a flashlight on hand. Once back together check and see if it shifts F-N-R. I manage to get N-R sometimes 😳 NO matter how I try not to!
              #16263
              billy-t
                Thanks that is all really helpful, really appreciate it.
