Home Forum Ask A Member Armature Plate Grease
  • #1582
    aquasonic
      I’m looking for some opinions on what kind of grease is preferable for the armature plate hub and the brass armature plate mount on OMC classics.
      I have been using OMC Triple Guard and it works OK, but somewhere I read that Lubriplate 105 is actually better for this application.
      Thanks
      #16712
      weedlessdrive
        I think any white lithium will work there.
        #16714
          The OMC Triple Guard is fine there. Just a light coat though….any grease that is too thin, and too thickly applied, will bugger up the points.
          #16715
            What Chris said. In fact, the factory routinely applied way to much of their "Type A", and it liquefied under vibration and fouled the points. Just a thin smear is all it needs, any more is just excess.
            #16719
            aquasonic
              Thanks Gentlemen. Now that I see these comments, I realize that I also have been applying too much grease on this assembly. I have been emulating what I’ve seen from the factory, but they apparently didn’t ALWAYS know what’s best.
              I have been
              #16754
              fleetwin
                US Member - 2 Years
                Use the OMC "moly lube" sparingly for this application.
