Home Forum Ask A Member Dents in aluminum tank
  • #1498
    deltonmike
      Any Suggestions/tricks on getting dents out of Aluminum Neptune tanks I don’t want to paint it.
      #16031
      RICHARD A. WHITE
        Outboarder had an article..many many years ago cut a patch out of the tank in a location that is hidden by the flywheel, and pound the dents out.. re-weld patch back in place. It will take time and patience but results can be amazing….
        classicomctools@gmail.com
        #16033
        deltonmike
          thanks Richard
          #16045
          Steve A W
            US Member - 2 Years
            DeltonMike
            Welcome to the forum.
            Here’s some links to a couple of video’s from member Tubbs working a couple tanks.
            https://www.youtube.com/watch?v=JYFQOiSc8UY
            https://www.youtube.com/watch?v=tnJAbxWInHw
            Good Luck with Your tank.
            Steve A W
            Member of the MOB chapter.
            I live in Northwest Indiana
            #16047
              Here’s a bit of info from an old Johnson Service Manual.
              #16053
              RICHARD A. WHITE
                40 lbs?????!!!!!!!
                #16088
                legendre
                  quote Richard A. White:
                  40 lbs?????!!!!!!!
                  Yes.. 40 lbs!!!!!!
                  Or so they say, lol. I don’t see why an otherwise-solid tank couldn’t withstand 40 psi.. but dang, wear some protective gear, including heavy-duty eye and ear protection. The freakiest part for me, is the ‘playing of the torch’ flame.. aluminum tends to get really soft, really quickly.. and not in a very controllable fashion.
                  #16092
                  RICHARD A. WHITE
                    My thoughts are at 40 lbs and if you don’t have ALL sides and ends blocked in..this thing will look like a balloon. Especially after you add heat and soften the material. Jay Walls when holding a workshop, explained using only 9 lbs, and went so far as to say, Not 8, not 10 but 9 lbs of pressure. I personally have not used air.
                    regards
                    Richard
                    #16098
                    The Boat House
                      • This reply was modified 5 years, 10 months ago by The Boat House.
                      • This reply was modified 3 years, 7 months ago by The Boat House.
                      #16104
                      weedlessdrive
                        Tubs that bench is cleaner than my socks. I didn’t get my family OCD gene. Lol
