Home Forum Ask A Member HD/TD Float Height
Viewing 11 post (of 11 total)
  • #18099
      Crankcase compression is expected to do it. If you check out the crankcase you will see the gap at the top of the bushing which is drained by that tube to the low speed venturi. There is a slinger ring on the crankshaft their that throws the oil creeping up the shaft into that channel.
