Home › Forum › Ask A Member › Hydraulic tilt for 1963 and 1970 40hp Evinrude / Johnson
- This topic has 7 replies, 4 voices, and was last updated 10 years, 6 months ago by
Monte NZ.
June 26, 2015 at 6:14 am #1863
Hi everyone.
Was there ever a hydraulic tilt unit available for the above motors.
I had a hunch that I had seen one several years back on a 40hp Johnson.
Age is catching up with me and I thought it would be interesting to see if they were ever produced, as it could make boating a bit easier
if I could find one.Thanks in anticipation
Monte NZJune 26, 2015 at 1:20 pm #18946No OEM tilt for these motors. Could adapt an aftermarket one. CMC make one for example that will work
June 26, 2015 at 1:37 pm #18947Never heard of, or seen a factory tilt for Big Twins, but CMC Marine offers a power tilt and trim unit for motors up to 35hp- but since modern 35’s are propshaft rated and/or four strokes (heavy), it should be fine for older 40hp motors. http://www.cmcmarineproducts.com/produc … p-to-35-HP
June 26, 2015 at 7:07 pm #18959You guys ready for a surprise? Check this:
June 26, 2015 at 11:12 pm #18971Okay, but I still haven’t seen one in person…. have you, Frank? Got to be pretty rare if they do actually exist. ($$$$$$)
June 27, 2015 at 1:31 am #18985Nope, I can’t say that I’ve ever seen one. But marineengine has a 172070 (33hp) for $400. Did somebody mention $$$$$$? The electric/hydraulic power unit was also used on other models, which I’ve seen. But I don’t know what sort of contraption it uses on the 33-40.
June 27, 2015 at 4:22 pm #19017As scarce as it may be, I will still bow to the Master. Well played, Frank.
June 28, 2015 at 2:07 am #19067Hullo everyone.
Thanks very much all of you for your replies and thanks too Frank,for posting the 1970 listing proving that they were available…….my memory hasn’t gone to the dog’s after all!!!
The price of $400 US, when converted to New Zealand dollars plus freight plus GST would make it a very expensive exercise!!!
I guess even in USA, the $400 dollar price tag would put a lot of people off purchasing one.
On the basis that you chaps haven’t seen one over your way,the chances of picking up a second hand one here would be most unlikely.
The only other thought I have ,is would it be possible to modify a tilt unit of a later 50hp?……….I will see if I can learn anything from dealers down here.Thanks very much again for your input………you certainly are a very knowledgeable bunch of guys!!
Keep up the good work!
MonteNZPS I will check out the price at CMC Marine just for curiosity,but I suspect that it will still cost a lot.
