Home › Forum › Ask A Member › Johnson HD-25 In saltwater
- This topic has 9 replies, 6 voices, and was last updated 9 years, 3 months ago by vwbusman66.
June 18, 2015 at 4:24 pm #1787
Hi all, I am wondering if it would be OK if I ran my engine in salt water. I am aware of need to run fresh water through the motor after a use to help prevent corrosion, but is anything else necessary? Is even this necessary?
JamesJune 18, 2015 at 4:27 pm #18377I would not run my HD-25’s in salt water, no matter what. I wouldnt recommend it to anyone. I would fear for my driveshaft getting ruined
June 18, 2015 at 7:04 pm #18389Yea, I would save the salt water trips for your less desirable motors.
June 18, 2015 at 8:05 pm #18396I may take some flak for this, but IMHO you won’t harm the HD by using it in salt water periodically. (We are talking about the Atlantic or Pacific here, not the Great Salt Lake or Dead Sea?) As long as you wash it off afterwards and run it in a freshwater test tank it should shake off the salt like a duck. Heck, until I was 18 I didn’t think fresh water was for anything but drinking! I had a vague idea that in places like the Great Lakes and Minnesota there were 2 or 3 people who boated 😉 but the vast majority of boating worldwide was/is on salt water – and that’s where all my antique and classic motors were used up ’till then. (And some still used!) People in salt water places also deserve the fun of seeing a nice classic motor run!
I have a TD and a TN that I use each year at our Mystic Seaport meet and neither of them have seen any ill effects from use in Salt. Okay, I wouldn’t recommend it for a Ruddertwin, Clark Troller or a rare and valuable antique/classic like a Amphion, Cross Radial or Amarc. But the HD is a really common motor and Johnson did a pretty good job with their corrosion protection for that time. Actually, an HD or TD that had the L/U fasteners preped by a dip in Permatex or another silicone sealer, would probably hold up pretty well even under relatively long term salt exposure. It may even hold up better than many of the new motors do! I have a "dump find" 1965 Johnson CD-22 6hp that is used as a trolling motor on my Mako 19 that’s pretty much only seen use in salt since it was new in 1965. Properly prepped, waxed each year and washed off after use, it’s fine and still even sports 95% original paint!
June 19, 2015 at 2:06 am #18413Art,
No Flak here. Well said. I always enjoy your posts and your website. Bigtime Volvo 245 fan here as well!
June 19, 2015 at 11:52 am #18428quote 1946Zephyr:Yea, I would save the salt water trips for your less desirable motors.In all honesty, Id say that and HD-25 or TD-20 is not really a "desirerable" motor, and it probably doesn’t get more common than those.
quote lotec:I may take some flak for this, but IMHO you won’t harm the HD by using it in salt water periodically. (We are talking about the Atlantic or Pacific here, not the Great Salt Lake or Dead Sea?) As long as you wash it off afterwards and run it in a freshwater test tank it should shake off the salt like a duck. Heck, until I was 18 I didn’t think fresh water was for anything but drinking! I had a vague idea that in places like the Great Lakes and Minnesota there were 2 or 3 people who boated 😉 but the vast majority of boating worldwide was/is on salt water – and that’s where all my antique and classic motors were used up ’till then. (And some still used!) People in salt water places also deserve the fun of seeing a nice classic motor run!I have a TD and a TN that I use each year at our Mystic Seaport meet and neither of them have seen any ill effects from use in Salt. Okay, I wouldn’t recommend it for a Ruddertwin, Clark Troller or a rare and valuable antique/classic like a Amphion, Cross Radial or Amarc. But the HD is a really common motor and Johnson did a pretty good job with their corrosion protection for that time. Actually, an HD or TD that had the L/U fasteners preped by a dip in Permatex or another silicone sealer, would probably hold up pretty well even under relatively long term salt exposure. It may even hold up better than many of the new motors do! I have a "dump find" 1965 Johnson CD-22 6hp that is used as a trolling motor on my Mako 19 that’s pretty much only seen use in salt since it was new in 1965. Properly prepped, waxed each year and washed off after use, it’s fine and still even sports 95% original paint!
Art, thank you for the detailed response. It is exactly what I needed to hear.
Thanks to all, JamesJune 19, 2015 at 4:05 pm #18437Actually…the HD has a flush port on the back of the powrhead under the lift handle on the shroud where you can hook up a 1/4 nipple with some adapter to garden hose thread and this thoroughly flush that motor without even running it.
It is a plug at the base that looks like a gearcase fill/drain plug.
Greg
June 19, 2015 at 5:59 pm #18441quote gjonz:Actually…the HD has a flush port on the back of the powrhead under the lift handle on the shroud where you can hook up a 1/4 nipple with some adapter to garden hose thread and this thoroughly flush that motor without even running it.It is a plug at the base that looks like a gearcase fill/drain plug.
Greg
Even better! I actually have never owned an old outboard and just bought my first motor, a 1949 HD-25 and Id like to use it when I vacation in Maine.
JamesJune 19, 2015 at 7:11 pm #18446Well, they may be common and less desirable, but not near as common and reliable as that CD-22 😀
June 19, 2015 at 9:09 pm #18452quote 1946Zephyr:Well, they may be common and less desirable, but not near as common and reliable as that CD-22 😀This is true!
